How to create a dropdown in C#?
I have a list on enums:
public enum PanelType
Undefined,
Wall,
WallExternal,
WallInternal,
and trying to make a component that will allow user to select via the drop down… here is my GH script for the component below. Any help will be really appreciated
namespace SAM.Analytical.Grasshopper
public class AnalyticalPanelType : GH_Component
/// <summary>
/// Panel Type
/// </summary>
public AnalyticalPanelType()
: base("AnalyticalPanelType", "AnalyticalPanelType",
"Snap Panels",
"SAM", "Analytical")
public override bool AppendMenuItems(ToolStripDropDown menu)
base.AppendMenuItems(menu);
ToolStripDropDown toolStripDropDown = new ToolStripDropDown();
foreach (PanelType panelType in Enum.GetValues(typeof(PanelType)))
toolStripDropDown.Items.Add(panelType.ToString());
Control control = new Control();
global::Grasshopper.Kernel.GH_DocumentObject.Menu_AppendCustomItem(toolStripDropDown, control);
return true;
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_InputParamManager inputParamManager)
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_OutputParamManager outputParamManager)
outputParamManager.AddGenericParameter("PanelType", "PanelType", "Analytical PanelType", GH_ParamAccess.item);
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="dataAccess">The DA object is used to retrieve from inputs and store in outputs.</param>
protected override void SolveInstance(IGH_DataAccess dataAccess)
/// <summary>
/// Provides an Icon for the component.
/// </summary>
protected override System.Drawing.Bitmap Icon
get
//You can add image files to your project resources and access them like this:
// return Resources.IconForThisComponent;
return Resources.HL_Logo24;
/// <summary>
/// Gets the unique ID for this component. Do not change this ID after release.
/// </summary>
public override Guid ComponentGuid
get { return new Guid("25a6b405-19ab-4ff1-9666-7760997ccfdd"); }
private PanelType panelType = PanelType.Undefined;
/// <summary>
/// Panel Type
/// </summary>
"Snap Panels",
public override bool Write(GH_IWriter writer)
writer.SetInt32("PanelType", (int)panelType);
return base.Write(writer);
public override bool Read(GH_IReader reader)
int aIndex = -1;
if (reader.TryGetInt32("PanelType", ref aIndex))
panelType = (PanelType)aIndex;
return base.Read(reader);
protected override void AppendAdditionalComponentMenuItems(ToolStripDropDown menu)
GH_Component.Menu_AppendItem(menu, panelType.ToString(), Menu_PanelTypeChanged).Tag = panelType;
base.AppendAdditionalComponentMenuItems(menu);
private void Menu_PanelTypeChanged(object sender, EventArgs e)
if (sender is ToolStripMenuItem item && item.Tag is PanelType)
//Do something with panelType
this.panelType = (PanelType)item.Tag;
ExpireSolution(true);
/// <summary>
/// </summary>
/// <summary>
/// </summary>
/// <summary>
/// </summary>
dataAccess.SetData(0, panelType);
/// <summary>
/// </summary>
get
/// <summary>
/// </summary>
@michaldengusiak this post is really useful! When I am defining the panelType variable I got the error that PanelType does not contain Undefined. Do you think it is a problem with the references? Any advice?
using System;
using System.Collections.Generic;
using System.Windows.Forms;
using GH_IO.Serialization;
using Grasshopper.Kernel;
using Rhino.Geometry;
using Rhino.UI;
namespace ExtendingGUIList
public class DropDownExample : GH_Component
/// <summary>
/// Initializes a new instance of the DropDownExample class.
/// </summary>
public DropDownExample()
: base("DropDownExample", "Nickname",
"Description",
"AIOS", "Subcategory")
int aIndex = -1;
/// <summary>
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
/// <summary>
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddGenericParameter("PanelType", "PanelType", "PanelType is the best", GH_ParamAccess.item);
/// <summary>
/// </summary>
/// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param>
protected override void SolveInstance(IGH_DataAccess DA)
/// <summary>
/// </summary>
get
return null;
/// <summary>
/// </summary>
get { return new Guid("7C82C338-CB29-4544-B3BC-5463DDB0CE65"); }
hello, I had the same issue; replying late should it help others he’s the solution:
You’ve forgotten to add the enumerated list object in Michal’s original post, add this code:
Undefined,
Wall,
WallExternal,
WallInternal,
Note, PanelType is the name of the Rhino.UI object type and is a keyword from the API.
panelType is the chosen name for the object created from the new constructor by the author. (hint: edit this name)
