C# creating automatic sliders
Hey !
I am trying to create multiple sliders based based upon an integer input. I have modified James -ramden code:.
The problem is it works fine on the first attempt, but the number of sliders increases exponentially , I want them to erase the old sliders and generate new ones according to the integer input.
Here is my modified code.
private void RunScript(bool x, object y, int z, ref object A)
Random rnd = new Random();
int i = 0;
if(x)
  for(i = 0;i < z;i++)
    //instantiate  new slider
    Grasshopper.Kernel.Special.GH_NumberSlider slid = new Grasshopper.Kernel.Special.GH_NumberSlider();
    slid.CreateAttributes(); //sets up default values, and makes sure your slider doesn't crash rhino
    //customise slider (position, ranges etc)
    int inputcount = this.Component.Params.Input[1].SourceCount;
    slid.Attributes.Pivot = new System.Drawing.PointF((float) this.Component.Attributes.DocObject.Attributes.Bounds.Left - slid.Attributes.Bounds.Width - 30, (float) this.Component.Params.Input[1].Attributes.Bounds.Y + inputcount * 30);
    slid.Slider.Maximum = 10;
    slid.Slider.Minimum = 0;
    slid.Slider.DecimalPlaces = 2;
    slid.SetSliderValue((decimal) (rnd.Next(1000) * 0.01));
    //Until now, the slider is a hypothetical object.
    // This command makes it 'real' and adds it to the canvas.
    GrasshopperDocument.AddObject(slid, false);
    //Connect the new slider to this component
    this.Component.Params.Input[1].AddSource(slid);
Any help will be much appreciated
Guys any luck?
Shout out the dark lord.
In addition to this, lets say I have a component that has 3 inputs and input 2 has two sliders connected to it. I want to delete these sliders when solution is generated. I want to do this because so that I can add new sliders to input 2 for another solution- i will plugin the code for generating new sliders which would get connected to input 2 automatically.
You can use IGH_Param.Sources to get a list of source parameters and then GH_Document.RemoveObjects Method to remove them:
aditya
  private void RunScript(bool x, List<object> y, int z)
    if(x)
      if(this.Component.Params.Input[1].SourceCount > 0)
        List<IGH_Param> sources = new List<IGH_Param>(this.Component.Params.Input[1].Sources);
        GrasshopperDocument.RemoveObjects(sources, false);
      for(int i = 0;i < z;i++)
tognatta.aditya.gh (14.9 KB)
@Mahdiyar this works, but I’am afraid gives me this error. Appreciate the quick response. Refer image below
Furthermore, If I want to connect this to another component Input(x), How do I go about this.
Rationally, I should try and find the component first and use <input .AddSource(myslid); >on that component. But how do I find that component through component name or ID? I could use FInd component from NodeinCode but the I’am afraid it will find similar components on the canvas.
Any suggestions.
You can get rid of this error by scheduling a new solution and registering a callback:
    if(x && z != _z)
      GrasshopperDocument.ScheduleSolution(5, SolutionCallback);
    _z = z;
  // <Custom additional code>
  private int _z;
  private void SolutionCallback(GH_Document doc)
    for(int i = 0;i < _z;i++)
tognatta.aditya (new solution).gh (13.8 KB)
P.S. Obviously you can also get rid of this error by activating Do not show this message again check box.
If you want to know why you get this message, you need to read @DavidRutten explanation here.
Got that! Appreciate the prompt response.
Did you read the text below the image on my previous reply?Any suggestions or insight on it will be helpful
aditya%202
private void RunScript(bool reset, string compoentnName, int n)
    if(reset)
      _n = n;
      _compoentnName = compoentnName;
  private int _n;
  private string _compoentnName;
    foreach(IGH_DocumentObject obj in GrasshopperDocument.Objects)
      if (obj.NickName == _compoentnName)
        IGH_Component targetComponent = obj as IGH_Component;
        if(targetComponent.Params.Input[1].SourceCount > 0)
          List<IGH_Param> sources = new List<IGH_Param>(targetComponent.Params.Input[1].Sources);
        for(int i = 0;i < _n;i++)
          int inputcount = targetComponent.Params.Input[1].SourceCount;
          slid.Attributes.Pivot = new System.Drawing.PointF((float) targetComponent.Attributes.DocObject.Attributes.Bounds.Left - slid.Attributes.Bounds.Width - 30, (float) targetComponent.Params.Input[1].Attributes.Bounds.Y + inputcount * 30);
          targetComponent.Params.Input[1].AddSource(slid);
        break;
tognatta.aditya (Another Component).gh (15.1 KB)
@Mahdiyar thanks a ton, this works like a charm.
Further taking this discussion, is there a way to name them?
@Mahdiyar Using the code above can i do custom nicknames with a list of string input?
Hi @Mahdiyar If we want to determine which slides are added to which component input code? For example, in the example below, I want to add to the second input, the Radius(Gh_input.(index))
tognatta-select hh input(index).gh (8.2 KB)
hi @Mahdiyar
I succeeded to solve myself to answer the problem above :innocent:
add slider advance.gh (10.5 KB)
  private void RunScript(bool reset, string compoentnName, int n, int a, int b, int @Decimal, int indexInput)
  if(reset)
  _n = n;
  _a = a;
  _b = b;
  _Decimal = Decimal;
  _indexInput=indexInput;
private int _n;
private int _a = 0;
private int _b = 10;
private int _Decimal ;
private int _indexInput;
      if(targetComponent.Params.Input[_indexInput].SourceCount > 0)
        List<IGH_Param> sources = new List<IGH_Param>(targetComponent.Params.Input[_indexInput].Sources);
        int inputcount = targetComponent.Params.Input[_indexInput].SourceCount;
        slid.Attributes.Pivot = new System.Drawing.PointF((float) targetComponent.Attributes.DocObject.Attributes.Bounds.Left - slid.Attributes.Bounds.Width - 30, (float) targetComponent.Params.Input[_indexInput].Attributes.Bounds.Y + inputcount * 30);
        slid.Slider.Maximum = _b;
        slid.Slider.Minimum = _a;
        slid.Slider.DecimalPlaces = _Decimal;
        slid.SetSliderValue((decimal) (rnd.Next(1000 * _b / 10) * 0.01));
        targetComponent.Params.Input[_indexInput].AddSource(slid);
      break;
thanks
