Hello everyone,
I’m new to Rhino and I’m trying to find the correct workflow for creating a sculpture.
I generated a 3D sculpture using Tripo AI and imported the mesh into Rhino 8. My idea is to use the AI model only as a reference and then rebuild the sculpture properly using Rhino curves and surfaces.
The problem I have is that I want to draw interpolated curves directly following the shape of the sculpture while working in Perspective view, but Rhino always places the curves on the construction plane (ground plane) instead of on the mesh.
What I would like to do:
- Keep the AI mesh as a 3D reference.
- Draw curves following the edges/shape of the sculpture.
- Use those curves later to create clean surfaces.
I tried using silhouette extraction, but the result is not accurate enough for this sculpture.
What would be the recommended Rhino workflow for this?
Should I use Pull, Project, Curve on Mesh, QuadRemesh, SubD, or another method?
I would really appreciate any advice because I’m still learning Rhino.
Thank you very much!
