How to connect horizontal points?
Hi !
How to connect ( with line ) horizontal points ?
( I have lines separated by dots, Lines are made from one by copying it )
0-0-0
1-1-1
2-2-2
10-10-10
0-0-0.gh (6.5 KB)
use the polyline component after the flip matrix.
Also make sure when posting to internalize (right click curve component) any Rhino geometry.
Rickson , thank you very much !
Rickson , Is it possible to use line instead of polyline ?
Скриншот 07-07-2020 152006
I was able to do it
thanks for the idea
Notice that you’re also connecting the purple with the green with what you’re showing on the screen
fyi, you have a list of 3 points, against another list (shifted -2), which will create 3 lines for each branch (points 0-1,0-2,1-2).
Thank you
Ок , Rickson , thank you
