How To close a surface in Grasshopper
Hi Guys! plz I need help removing vertical seams from an extruded surface and closing the geometry to make it a solid in Grasshopper. Any tips?? Thanks!
practice_sae_exercice.gh (14.9 KB)
You need to make sure that the last item in the list is being moved the same as the first item in the list so that the seam moves together - alternatively you trim a part of the surface out and try to bridge in between them.
I’d post the file but I have a newer version of Gh - I’m sure you’ll be fine rebuilding this yourself
hey @Artstep
I followed your instructions, but unfortunately, the issue persists
Loft will do the trick
I think noise is better to move the point. But like that is also OK
practice_sae_exercice.gh (18.8 KB)
Thanks @laurent_delrieu
The solution you provided worked great!
You have connected the wrong output on TreeStatistics
