Hi all,
I am discovering step by step how to use the very promising HOPS module and its advantages + limitations. To that purpose, I am currently looking for a solution to connect an existing HOPS function to/within a CPython script in order to interact with grasshopper. Following the tutorial available here mainly focused on how to create a HOPS function from python to be used within grashhoper, I did not succeed in using it for example to interactively transfer/modify data from Cpython to modify an existing HOPS function’s inputs in grasshopper.
So I wonder if someone could give me some leads and explanations in order to solve this challenge. I will really apreciate it ![]()
Is there a solution ?
Thanks in advance for your help !
All the best,
Hervé
