How to batch exporting code from Python nodes?
I am currently working with Python script components in Grasshopper and have encountered a challenge that I believe others might also be facing. As part of my project documentation and possible sharing code as Jupyter Notebook, I want to export the Python scripts embedded within the Script and/or Python3 components en masse, rather than manually copying out each script one by one, and do so after each change. A manual process is time-consuming, especially when dealing with large definitions that contain multiple script components.
From my understanding and attempts (but i am no python expert), there doesn’t seem to be a straightforward method to programmatically access the Python script content directly from these components
What I’m looking for:
  • A way to programmatically extract all Python scripts from my Grasshopper document, ideally through a batch process.
  • Alternatively add a string output to each node that take it’s content. And then I append it from the panels and save it from there (hopefully ;)0
Thank you all for your help and time!
get_python_nodes_content.gh (8.4 KB)
Here is waht I have thus far, check by type and get guid
The ‘old’ GHPython components (type(comp) is GhPython.Component.ZuiPythonComponent, isinstance didn’t work) can be introspected from other components, by searching ghdoc.Component.Attributes.DocObject.OnPingDocument().Objects.
The code is simply a string in comp.Code
Found this issues .. seems to work as you hinted at only for IronPythin node, not Python3. I’ll link the topic to past post, with more info
Rhino 8 Python Grasshopper Component.Code Property - Grasshopper Developer - McNeel Forum
Have you seen this? Rhino 8 Python Grasshopper Component.Code Property - #19 by eirannejad
