I copied one polysurface several times whitout realizing I was moving them out of the plane I was originally working on. So now I have a bunch of polysurfaces all around my working area. How do I get them to align to the original plane?
Hello - the Align command should help- just keep in mind that it is a 2d command so it only applies to the current CPlane X and Y.
I tried using align then bottom, but they are moving from their position on the x,z plane What would be the best option so that wont happen?
ProjectToCplane?
Hello - better to post a file.
The Align command would act differently if you are in Top view or side view (Right/Left/Front/Back).
Try either and see if you can get the alignment to work per Pascal’s advice.
-j
