yongg0323
(Yongg0323)
1
Hi.
I’m trying to work with Galapagos, but I’m asking because I don’t think it’s efficient to manually move information into the “gene pool” component.
Is there a way to transfer the information from the panel to the “gene pool” component?
Thank you in advance.
gankeyu
(Keyu Gan)
2
Try GenePool Controlled from Heteroptera
yongg0323
(Yongg0323)
3
I used Heteroptera, but I don’t think it’s the way I want it to be.
The way I want is to move the information of the panel to the gene pool.
yongg0323
(Yongg0323)
5
If you don’t mind, could you show me an example of use?
yongg0323
(Yongg0323)
6
I checked and found that the component only had information about the number of lists, domains, decimal places, and random values.
I couldn’t find a way to move the value of the panel I wanted to the gene pool component.
gankeyu
(Keyu Gan)
7
My bad. Here’s an example of using custom script to copy data from Panel to GenePool.
genepool.gh (10.1 KB)
yongg0323
(Yongg0323)
8
Thank you so much for your kind reply!
Have a nice day.
Dadan007
(Dadan)
9
Do any one know how to achive this in ghpython?
This post demonstrates how to access and manipulate genepools using GHPython, and should get you started:
Dadan007
(Dadan)
11
Thank you sooooo much! This is exactly what I want.
