#Suggestion We can fine tune the genepool numbers with the" DoubleClick " and keyboard
@DavidRutten
@wim
@pascal
I think the answer is “no”. What I usually do is make the GenePool component as wide as I can given what else is on the screen, and then, when I need to set a precise value, zoom in to that part of the GenePool to make it really big and then make as tiny a pointer movement as possible.
Another approach is to lock the Solver and then fiddle with the slider in question until it gets close to the desired value. Sometimes I am able to hit the desired value after only a few times.
This is a problem if this is not possible and this operation does not require one click to set the exact number Let the developer think and answer
This component was created for use with Galapagos, where it really doesn’t matter much the value of the gene because it will be optimized by the solver. But yes, it would be a good feature to add. But from this point on, it’s almost better to have a system to anchor sliders (all source parameters) under each other, to create a parameters stack, right?
Yes, yes, but adding this to genepool does not contradict the purpose of creating it for the Galapagos
