Hi, I have a problem. When I use merge function to merge many curves become single curve, it seem to like one curve, but actually it still compose of many curves. I try to use the following method to merge…finally it still is polycurve. how to actually become one curve? Help!!
Dim t_flag As Boolean
Select_Entity_and_Give_Group_Name(5, "Select Curves", t_flag)
If t_flag = False Then
Exit Sub
End If
Dim obj As Rhino.DocObjects.RhinoObject
Dim i, j As Integer
Dim cur_list As New List(Of Curve)
Dim cur, cur_all As Curve
For i = 0 To CAD_Left_Relation_num - 1
obj = RhinoDoc.ActiveDoc.Objects.Find(CAD_Left_Relation_data(i))
cur = obj.Geometry.Duplicate()
cur_list.Add(cur)
Next
Dim num, num2 As Integer
num = cur_list.Count
Dim dumy_tt(num) As RMA.OpenNURBS.IOnCurve
Dim dumy_tt2(0) As RMA.OpenNURBS.OnCurve
Dim lines As New List(Of RMA.OpenNURBS.OnCurve)()
Dim kumy As RMA.OpenNURBS.OnCurve
For i = 0 To num - 1
kumy = Rhino.Runtime.Interop.ToOnCurve(cur_list.Item(i))
lines.Add(kumy)
Next
Dim fg As Boolean
fg = RMA.Rhino.RhUtil.RhinoMergeCurves(lines.ToArray(), dumy_tt2, 0.2)
Dim crvv As New RMA.Rhino.MRhinoCurveObject()
Dim curt As Curve
For i = 0 To dumy_tt2.Length - 1
crvv.SetCurve(dumy_tt2(i))
kumy = crvv.Curve.DuplicateCurve()
curt = Rhino.Runtime.Interop.FromOnCurve(kumy)
RhinoDoc.ActiveDoc.Objects.AddCurve(curt)
Next
Rhino.RhinoDoc.ActiveDoc.Views.Redraw()
cur_list.Clear()
