How to access Context Menu icons, like "Flatten" icon?
Hello, I am developing a custom component GUI for my grasshopper plugin.
How can I access the default Context Menu icons?
For example if I want to put an “Expression Editor” icon next to the input,
GH_DocumentObject.Menu_AppendItem(toolStripMenuItem.DropDown, “Expression Editor”, new EventHandler(this.ExpressionEditor), ??? null);
or render the Expression rectangle by the input grip, or any other default icons
I saw there is a GH_StateTag class, but doesn’t seems to offer anything
After a while, I found the Res_ContextMenu class with all the bitmaps, but it is an internal class.
Did I miss something in the API?
@DavidRutten
Thanks
bump
I don’t think you can access the Res_ContextMenu ResourceManager from another assembly. One workaround is to just grab the bitmap from other already initialized menu items.
var menu = new System.Windows.Forms.ToolStripDropDown()
var param = new Grasshopper.Kernel.Parameters.Param_Number()
param.AppendAdditionalMenuItems(menu)
var expressionIcon = menu.Items[4].Image
