If you must know…
If (data Is Nothing) Then Return String.Format("Null {0}", name)
If (Not data.IsValid()) Then Return String.Format("Invalid {0}", name)
If (data.IsArc()) Then
If (data.IsClosed()) Then Return String.Format("{0}Circular {1}", prefix, name)
Return String.Format("{0}Arc-like {1}", prefix, name)
End If
If (data.IsEllipse()) Then
Return String.Format("{0}Elliptical {1}", prefix, name)
End If
If (data.IsLinear()) Then
Dim pts As Polyline = Nothing
If (data.TryGetPolyline(pts)) Then
If (pts.Count = 2) Then
Return String.Format("{0}Line-like {1}", prefix, name)
End If
End If
Return String.Format("{0}Linear {1}", prefix, name)
End If
If (data.IsPolyline) Then Return String.Format("{0}Polyline {1}", prefix, name)
Dim closed As String = String.Empty
Dim planar As String = String.Empty
If (data.IsClosed()) Then closed = "Closed "
If (data.IsPeriodic()) Then closed = "Periodic "
If (data.IsPlanar(0.001)) Then planar = "Planar "
Return String.Format("{0}{1}{2}{3}", prefix, closed, planar, name)
name
can be either "Curve"
or "Edge"
, and the prefix
is either an empty string or "Referenced"
