Hi, everyone.
I am try to evaluate a point on a trimmed surface with holes. How to make sure the point on the surface, not in the hole or outside the out loop?
my thought is to evaluate a point on its underlying surface and detemine if the point is on the trimmed surface. Is there better solution in rhinocommon.
any sugestion?
BTW: If no face overlaps exist … then a bool[ ] taken = new bool[pList.Count] could speed things (with regard the inner (j) loop as above).
So if you want to do something more (for instance given a planar face determine the inner Loop curves point relation or find the closest inner Loop curve etc etc) … you’ll need some lines of code more.
