How Do Professionals Use Rhino + Grasshopper in Real Projects?
Hi everyone,
I’m an architect with a background in SketchUp and AutoCAD, and I’ve been learning Rhino and Grasshopper for about a year. However, I’m still struggling to understand the complete workflow, particularly how computational design translates into real-world construction and documentation.
In SketchUp, my workflow is relatively straightforward: I create a 3D model, generate drawings using LayOut, add dimensions, and prepare most of the detailed architectural drawings in AutoCAD.
With Rhino and Grasshopper, I’m fascinated by the possibilities, but I’m struggling to understand what comes after the modelling and scripting stage.
For example:
  1. Complex geometries: If I create a complex façade or architectural form using Grasshopper, how do I take it from a parametric model to a buildable design? How do I develop construction details, fabrication drawings, and technical documentation?
  2. Construction documentation: What is the industry-standard workflow for generating plans, sections, elevations, details, and dimensions from Rhino? Do professionals use Rhino’s Make2D, Rhino Layout, Grasshopper scripts, or export geometry to AutoCAD or Revit?
  3. Generative design and Galapagos: Suppose I use Galapagos to explore multiple design possibilities and find an optimal solution for a building layout. What happens next? How do I develop the selected option into a coordinated architectural design that can actually be constructed?
  4. Real-world industry practice: How do architecture firms integrate Rhino and Grasshopper with tools such as AutoCAD, Revit, BIM software, and fabrication workflows? Which tasks are typically performed in each software?
  5. Learning the complete workflow: Are there any courses, tutorials, or project-based resources that demonstrate the entire process, from the initial concept and parametric modelling to construction drawings, detailing, and execution on site?
I understand the modelling and scripting aspects to some extent, but I want to understand the bigger picture: how industry professionals use Rhino and Grasshopper to deliver actual architectural projects, rather than stopping at an impressive 3D model or computational design study.
I’d really appreciate insights from architects, computational designers, and professionals who have used these tools on real projects, especially examples that demonstrate the workflow from concept to construction.
Thank you!
Rhino has extensive documentation tools that are just a google search away.
Here’s a Rhino heavy large project presentation. The Morpheus Hotel: From Design to Production: Live Webinar
Industrial /product design here. I don’t do any initial design in Rhino. When we need things like complex surface detail & patterns etc. (Grasshopper) then I export a STEP file, work on that STEP file in Rhino, Export a STEP again and take back into my CAD. It does mean that if the design updates, I need to come back into Rhino, go through the whole import / export process again. So I generally work with bump & normal maps for rendering / displacement / STL texturing for prototypes and leave the Grasshopper stuff till right at the end when the design is more locked down.
Thank you.
