How do I turn off the insertion point for a Block
How do I turn off the insertion point for Blocks ? I’ve tried PointsOff but no luck.
I am creating a render of riveted iron plates using Cycles. It looks pretty good except that the Block insertion points show through, looking like little light sources. Pretty annoying.
Also, exploding the Blocks is not an option since there are thousands of them.
Hello - the insertion point should only show if points are on. Are you sure there is not a point included in the block definition?
You are a genius :slight_smile: Thanks.
Chris
