How do I stop running CRhinoGetObject?
I use CRhinoGetObject to get objects.
When I run CRhinoGetObject to get objects again, how can stop last running CRhinoGetObject?
Kind regards,
Vaker
Can you post the code that is giving you this problem? I don’t quite understand what you mean.
Meanwhile, there is this example:
http://developer.rhino3d.com/guides/cpp/selecting_objects/
The “Add” button on a dialog:
Source code:
User clicked “Add” button 2 times.
User do nothing at the first time.
CRhinoGetObject still waiting seclection.
When user clicked “Add” button the second time, I want to stop CRhinoGetObject at the first time.
How can I do?
Kind regards,
Vaker
Hi Vaker,
Instead of embedding object picking inside of your button code, have your button run commands that run the object picking (instead). For example:
void CTest_Page::OnBnClickedAddbutton()
  RhinoApp().RunScript(L"! AddButtonCommand", 0);
void CTest_Page::OnBnClickedRemovebuttion()
  RhinoApp().RunScript(L"! RemoveButtonCommand", 0);
The “!” will cancel the previous CRhinoGetObject.
You could also disable your UI while picking was running. This way, they couldn’t pick the other button.
– Dale
Hi Dale,
I use first way to fixed the problem.
Thanks for your help.
Kind regards,
Vaker
