How can we use the drawn curves as the UV Directional Curves?
Hi guys, The left one is the UV altered surface and i have the curves drawn on the the right side , i want those curves act as UV direction so that i will import it to grasshopper and have circular patterns in those directional curves. Please help with this thanks in advance guys. If it is possible in grasshopper to change also please do the needful.
Pls share your file, this would make easier to help you.
UV Align Curve.3dm (356.8 KB) yes please check.
Not sure if this is what you’re looking for:
UV Align Curve.gh (7.6 KB)
Not this. I want the surface uv curves to be like that. If i connect quad panel that will have different directions in according to uv. Is there anyway that our drawn curves can be our uv curves in a surface. Not by individual set of loft, etc.
My apologies but I’m not understanding the result you want. Would be able to add a sketch to show the effect you want to achieve?
