Hello I haven’t been programming for long and would like to use an entry in an eto window for another code, can someone help me. Thank you ![]()
I mean how can i use the Variable which entered here: self.m_textbox = forms.TextBox(Text = None)
I just use the code from this site.
# Imports
import Rhino
import scriptcontext
import System
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
# SampleEtoRoomNumber dialog class
class SampleEtoRoomNumberDialog(forms.Dialog[bool]):
# Dialog box Class initializer
def __init__(self):
# Initialize dialog box
self.Title = 'Sample Eto: Room Number'
self.Padding = drawing.Padding(10)
self.Resizable = False
# Create controls for the dialog
self.m_label = forms.Label(Text = 'Enter the Room Number:')
# Create the default button
self.DefaultButton = forms.Button(Text = 'OK')
self.DefaultButton.Click += self.OnOKButtonClick
# Create the abort button
self.AbortButton = forms.Button(Text = 'Cancel')
self.AbortButton.Click += self.OnCloseButtonClick
# Create a table layout and add all the controls
layout = forms.DynamicLayout()
layout.Spacing = drawing.Size(5, 5)
layout.AddRow(self.m_label, self.m_textbox)
layout.AddRow(None) # spacer
layout.AddRow(self.DefaultButton, self.AbortButton)
# Set the dialog content
self.Content = layout
# Start of the class functions
# Get the value of the textbox
def GetText(self):
return self.m_textbox.Text
# Close button click handler
def OnCloseButtonClick(self, sender, e):
self.m_textbox.Text = ""
self.Close(False)
# OK button click handler
def OnOKButtonClick(self, sender, e):
if self.m_textbox.Text == "":
self.Close(False)
else:
self.Close(True)
## End of Dialog Class ##
# The script that will be using the dialog.
def RequestRoomNumber():
dialog = SampleEtoRoomNumberDialog();
rc = dialog.ShowModal(Rhino.UI.RhinoEtoApp.MainWindow)
if (rc):
print dialog.GetText() #Print the Room Number from the dialog control
# Check to see if this file is being executed as the "main" python
# script instead of being used as a module by some other python script
# This allows us to use the module which ever way we want.
if __name__ == "__main__":
RequestRoomNumber()
