How can I set CPlane once in one viewport but affects to all viewports?
I used to be able to set CPlane in one viewport and it is relatively changed to all viewports. For example, if I set the CPlane origin to one point of the object in perspective viewport then all CPlanes in other viewports such as top, front and right viewports will be relatively reset following the perspective one.
Right now, I can’t do it anymore. I set CPlane in one viewport but others remain unchanged.
How can I create this setup?
Thank you
Hi @sunnattapoom
Go to Rhino Options>Modeling Aids and set “Construction planes” to “Universal construction planes”
HTH, Jakob
Successed!
Thank you
