After that, only CRhinoDrawCallback::DrawDecorations is called. (expected behavior)
However, at Rhino 6, CRhinoDisplayConduit::ExecConduit is called many times with various channels. (For example, SC_PREDRAWOBJECTS etc.)
Therefore full drawing will be done.
Changing DISPLAY_HINT does not change the result.
It seems that the SetRedrawDisplayHint function doesn’t work at Rhino 6.
How can I refresh the screen without full drawing?
Rhino 6 SR15 (6.15.19164)
Rhino 6 C++ SDK (6.15.19164.21011)
I used 6.12.19029.06381 before. The issue was the same.
After calling Redraw at (A) above, the following (1) to (6) are called before returning from there.
(CRhinoDisplayConduit class is constructed with the channel_mask of CSupportChannels::SC_DRAWOBJECT|CSupportChannels::SC_PREDRAWOBJECTS|CSupportChannels::SC_CALCBOUNDINGBOX|CSupportChannels::SC_CALCCLIPPINGPLANES|CSupportChannels::SC_DRAWOVERLAY)
(1) CRhinoDisplayConduit::ExecConduit with nChannel == SC_CALCBOUNDINGBOX
(2) CRhinoDisplayConduit::ExecConduit with nChannel == SC_CALCCLIPPINGPLANES
(3) CRhinoDisplayConduit::ExecConduit with nChannel == SC_PREDRAWOBJECTS
(4) CRhinoDisplayConduit::ExecConduit with nChannel == SC_DRAWOBJECT
(5) CRhinoDisplayConduit::ExecConduit with nChannel == SC_DRAWOVERLAY
(6) CRhinoDrawCallback::DrawDecorations
For Rhino 5, even the same code will only call (6).
Is this behavior as expected?
I believe this is expected behavior now as the display is noticing the existence of conduits which may need to be executed. Is you display frame rate slow? If so, I may be able to help with your conduit code to speed things up.
