I have a rectangular mesh which is made of quads and triangles:
Is there a way to get the centreline surface representation of this mesh? I am new to Grasshopper.
I.e. Centreline surface of the thing 3D box:
Thanks
Thanks
maybe you can use the “Contour” command to do it.
mesh.3dm (152.7 KB)
Attached is the mesh, it was imported from an IFC using ggImportIFC. I haven’t got very far with any successful GH scripts.
Thanks!
@o.rush
Here you are:
for Oliver.gh (106.1 KB)
Thanks Ali, this seems to do the trick! Is there any way to get it in the same coordinates as the original mesh object?
@o.rush
you’re welcome. sorry for the delay. yes, you can use Orient Command:
for Oliver-2.gh (125.8 KB)
I don’t know why the Meshedit Plugin works weird in the Original Location and cant properly explode the Original Mesh, But it works fine when the mesh moves to the origin of coordination. anyway, I just use a workaround method but if you can find a way to explode the mesh to it’s faces properly in its original position, you won’t need the Orientation.
