Reverse Engineering: Accurately fitting surface to mesh
I have been trying to fit a surface to a tubular mesh accurately. However, I am facing issues in these two section sections.
Any ideas as to how I could approach this problem and accurately map these two sections? I have attached the grasshopper file for your consideration.
Reverse Enginnering Question.gh (450.8 KB)
Thank you so much for your help :slight_smile:
FYI,
Reverse Enginnering Question_01.gh (445.8 KB)
What’s happening here? And does this not mean GH can do this to any shape?
Yes, In fact, using QuadRemesh here will be faster, but the surface structure will be a little more complex, which may not be what @Gaurav_Chauhan wants.
Thank you so much this is exactly what I was looking for :slight_smile:
I think you marked my post as solution by mistake. This I think was the one you intended:
This stuff is mind blowing. I really like seeing GH do things like this! :slightly_smiling_face:
I had fallen very sick and perhaps it was that lingering. Thank you for the correction and your contribution :slight_smile:
