Hops subdefinition with a compute server
Hi! I’m using a compute server (installerd with IIS) with a fork of the appserver. I’d like to be able to use hops subdefinitions in the definitions that are computed by the server.
I understood from previosu exchanges that including my hops subcomponents in my blob storage wouldn’t work, so i tried by saving them on the compute server directly. I managed to make it work on the server by saving the hops subdefinition on the server, filling in API Key in the parameters for Hops and registering the path to the subdefinition in my definition as the path on the server
The thing is, it doesn’t work with the webapp. The page doesn’t crash so i guess there is no blocking error, but the component is definitely not computed. Here is a diagram of what i attempted to help.
Is there a way to make it work?
Thanks in advance!
Update: I tried with the hops file being stored on an open URL as @AndyPayne suggested here:
It works fine when i execute the “master” definition including hops component with GH GUI locally, but doesn’t work when i try and open the master definition with appserver + compute (locally or remotely)…
(For example when i try and compute with local compute, i get following message, the component being the one you see on the screenshot, implying hops component didn’t work)
CG  [10:59:36 DBG] Input parameter Z failed to collect data: component "Center Box" (1a5fd7be-4f00-449f-9068-2cdb4963a3af)
Any clues?
Thanks :pray: !
Are there any other messages in the logs other than the one that says the input failed to collect data? Have you tried sending a simple Hello World type of definition to your app server/ remote VM instance just to see if that workflow will work on simple definitions?
Hi @AndyPayne thanks for your quick reply.
There are no other messages:
CG  [10:42:14 DBG] Logging to C:\Users\quent\AppData\Local\Temp\Compute\Logs
CG  [10:42:14 INF] Child process started at 10/10/2024 10:42:14
CG  [10:42:15 INF] Compute 8.0.0.0, Rhino 8.9.24194.18121
CG  [10:42:15 DBG] Rhino system directory: C:\Program Files\Rhino 8\System
CG  [10:42:20 DBG] Hosting starting
CG  [10:42:28 INF] (1/3) Loading rhino scripting plugin
CG  [10:42:28 INF] Successfully loaded scripting plugin
CG  [10:42:29 INF] Configured scripting plugin for compute
CG  [10:42:29 INF] (2/3) Loading grasshopper
CG  [10:42:39 INF] (3/3) Loading compute plug-ins
CG  [10:42:40 DBG] Found module compute.geometry.FixedEndPointsModule
CG  [10:42:40 DBG] Found module compute.geometry.RhinoGetModule
CG  [10:42:40 DBG] Found module compute.geometry.RhinoPostModule
CG  [10:42:40 DBG] Found module compute.geometry.ResthopperEndpointsModule
CG  [10:42:40 INF] Now listening on: http://localhost:5000
CG  [10:42:40 INF] Application started. Press Ctrl+C to shut down.
CG  [10:42:40 INF] Hosting environment: Production
CG  [10:42:40 INF] Content root path: C:\Users\quent\Documents\Git\compute.rhino3d\src\bin\Debug\compute.geometry
CG  [10:42:40 DBG] Hosting started
CG  [10:43:06 DBG] Using cached definition
CG  [10:43:06 DBG] Input parameter Z failed to collect data: component "Center Box" (1a5fd7be-4f00-449f-9068-2cdb4963a3af)
Also, i have to add that i tried to run if on a vanilla local compute + appserver so if you want to try, i’ll attach the file.
Also yes, usual definitions work just fine, we’ve been using compute for quite some time now and our production runs on it. We need hops subdefinitions to industrialize parts of our process.
Here’s the original file, if you can try it it would be very appreciated.
hops_mother_git_link.gh (13.8 KB)
Thanks!
Ok. There is definitely a bug on our end. I’m working to figure out why this is happening and this will likely require a new build of hops/Rhino.Compute to get this working once the fix is in place. I will keep you updated. I have created a YouTrack (Compute-298) to track this issue.
Thanks @AndyPayne ! I’m absolutely looking forward to it. Please let me know if i can do anything to help :slight_smile:
