Hey I am trying Hops from CPython. Example works fine I was just trying to figure out Lists with CPython.
I have this with no compile errors:
@hops.component(
"/pointat",
name="PointAt",
description="Get point along curve",
icon="examples/pointat.png",
inputs=[
hs.HopsCurve("Curve", "C", "Curve to evaluate", access=hs.HopsParamAccess.LIST),
hs.HopsNumber("t", "t", "Parameter on Curve to evaluate", access=hs.HopsParamAccess.LIST),
outputs=[
hs.HopsNumber("P", "P", "Point on curve at t")
def pointat(curves, ts):
return len(curves)
But I am getting Requires at most 0 items in GH. Where do we set this?
Also in order to get autocomplete for list how should we hint that to python? I saw in the examples that you were doing something like that for a single input. Any thought for a list and even a tree?
def pointat(curve: rhino3dm.Curve, t=0.0):
return curve.PointAt(t)
