Hops error
def foo(mesh,dist,depth,iter):
    second_mesh=Rhino.Geometry.Mesh()
    vec_normal=System.Collections.Generic.List[Rhino.Geometry.Vector3d]()
    re_pts=System.Collections.Generic.List[Rhino.Geometry.Point3d]()
    for i in mesh.vec_normal:
        vec_normal.Add(Rhino.Geometry.Vector3d(i))
    for i in range(len(mesh.Vertices)):
        temp_point=Rhino.Geometry.Point3d.Add(Rhino.Geometry.Point3d(mesh.Vertices[i]),vec_normal[i])
        re_pts.Add(temp_point)
        second_mesh.Vertices.Add(temp_point)
    print(type(mesh.Facevec_normal))
    for i in range(len(mesh.Faces)):
        if mesh.Faces[i].IsQuad:
            ve1 = mesh.Faces[i].A
            ve2 = mesh.Faces[i].B
            pt_1 = re_pts[ve1]
            pt_2 = re_pts[ve2]
            mid_1 = Rhino.Geometry.Point3d.Divide(Rhino.Geometry.Point3d.Add(pt_1,pt_2),2)
            mid_1= Rhino.Geometry.Point3d.Add(mid_1,Rhino.Geometry.Vector3d(mesh.Facevec_normal[i]))
this throws the error:
  1. Exception occured in handler:
    No constructor matches given arguments: (<class ‘Rhino.Geometry.Collections.MeshFaceNormalList’>)
    File “.\app.py”, line 59, in mesh_ex
    mid_5= Rhino.Geometry.Point3d.Add(mid_5,Rhino.Geometry.Vector3d(mesh.FaceNormals))
    but what is wrong here? because I tried itin GHPython and it works perfect but now in HOPS it is throwing an error.
