I tried to use rhino inside with hops as I want to use rhinocommon and python external library such as open3d, numpy, and convert it back and forth between rc and the library. Currently, I used ghpythonremote. It works, but when lets say I convert pts3d from rhinocommon to nparray, it takes a lot of time.
So, I am wondering if it is possible to use rhinoinside with hops?
below are the sample code:
from flask import Flask
import ghhops_server as hs
import rhinoinside
rhinoinside.load()
import System # noqa
import Rhino # noqa
# register hops app as middleware
app = Flask(__name__)
hops = hs.Hops(app)
@hops.component(
"/test",
name="test",
description="create Line",
#icon="examples/pointat.png",
inputs=[
hs.HopsPoint("p1"),
hs.HopsPoint("p2"),
outputs=[
hs.HopsLine("l"),
def main(pt1, pt2):
return Rhino.Geometry.Line(pt1, pt2)
if __name__ == "__main__":
app.run()
However, somehow it show an error as below:
anyone know what is the issue? I guess I missing something…
Here is the python file:
app.py (589 Bytes)
Thanks
