Honeybee Daylight analysis fail
Hello! I’m trying to do a very simple analysis of spatial daylight autonomy. At first I got an error while running the analysis, since it has multiple floors (10 floors with 2.7 of height). I tried doing an analysis in each floor but I got an error saying that the “sensor grid didn’t had a light path”. I disconnected the gene pool, simulating each floor, therefore, each room.
I’m sorry if I misunderstood some information regarding the use of Honeybee. I’ve try everything in my knowledge to fix it. Now I used only one floor and it stopped the error, clearly it was because I didn’t put the data in a correct way to simulate 10 floors (If you could please help me with this, because I found a component of an older version that could do this but I don’t know how to do it with the update).
Ok so I ran the analysis with just one floor, it worked, at least, is not red anymore. But the results are empty. I don’t understand clearly why this could be so I really would appreciate some help.
Thank you so so much for your help!! <3
try5.gh (863.1 KB)
