In this video I have deleted a block on the left side of the mirrored work. Then when I take the mirror option, it highlights the not mirrored or missing objects. It is in RHINO 4,but in rhino 8, it is not highlighting.
Look at this topic:
Thanks for your reply.
Sir, it is not about only blocks, it is about all objects - may be polysurfaces ,surfaces, curves,points, all will be highlighed which are not mirred.
I don’t think there is a way to find mirrored geometry other than blocks.
For blocks, you don’t even need the script, there’s a command called _SelMirroredBlocks
Thanks for the information,Sir. Rhinoceros is improving a lot but one good thing hasn’t been brought forward. I think Sometimes old things come in handy.ok sir thank you so much.
