With Rhino 5, when I select a curve, it doesn’t show the control points for that particular curve unless I turn them on. On the beta version however, it’s constantly on, and it’s so annoying. Even if I turn them off by using the F11 hotkey, it turns on the moment I select the curve again.
Is this a bug, or is there a way to turn the points off? It makes the work environment really busy when dealing with multiple curves. I should be able to turn them on, only when I need them.
