Hide Layer from printing?
Hi
I’m using Rhino to draft some 2d drawings. I have a layer with curves defining the print space (not standard sizes, each image changes) - is it possible to somehow make the layer “unprintable”? I need it visible when selecting my print window
thanks!
You can define the layer print width as “No Print”. You will be able to see it in model space - as long as you have PrintDisplay turned off. It will not show up in the print preview nor be printed.
Another way to do this is to lock the layer, and in the print dialog, visibility section, uncheck “Locked objects”. They will be visible on-screen even if PrintDisplay is turned on, but they will not print.
ah thanks so much, it worked!
