HiddenLineDrawingSegment not supporting Clipped segments?
It seems that “Rhino.Geometry.HiddenLineDrawingSegment.Visibility.Clipped” type is currently not supported.
Whenever I define a clipping plane and Compute, only visible and hidden segments are returned, but never clipped segments.
@DavidRutten also excluded the clipped curves as outputs of the “Make2D” grasshopper component.
Does that mean that “Clipped” segments are currently not supported by “HiddenLineDrawingSegment” class?
@djordje what do you need the HiddenLineDrawingSegment.Visibility.Clipped segments for?
Are you trying to find ClippingPlane intersections with your geometry?
Hi @rajaa,
Yes. I have an object in the perspective view, and I would like to “identify” the clipping plane Make2D lines. But the “HiddenLineDrawingSegment.Visibility.Clipped” seens to not work.
Ok, I’ll put together a sample for you to extract intersection curves with the clipping plane.
This code will select objects and use active clipping plane to output Make2D curves.
Is that what you are looking for?
      var _go = new GetObject();
      _go.SetCommandPrompt("Select objects to test Make2D");
      _go.GeometryFilter = ObjectType.Point | ObjectType.Surface | ObjectType.PolysrfFilter;
      _go.GroupSelect = true;
      _go.GetMultiple(1, 0);
      if (_go.CommandResult() != Result.Success)
        return _go.CommandResult();
      var _obj_refs = _go.Objects();
      var _view = doc.Views.ActiveView;
      //Set Make2D Parameters
      var _hld_params = new HiddenLineDrawingParameters
        AbsoluteTolerance = doc.ModelAbsoluteTolerance,
        IncludeTangentEdges = false,
        IncludeHiddenCurves = true
      _hld_params.SetViewport(_view.ActiveViewport);
      //add objects to hld_param
      foreach (var obj_ref in _obj_refs)
        if (null == obj_ref)
          continue;
        var obj = obj_ref.Object();
        if (null == obj)
          continue;
        _hld_params.AddGeometry(obj.Geometry, Transform.Identity, obj.Id);
      //Add active clipping planes
      var clipping_planes = doc.Objects.GetObjectsByType<ClippingPlaneObject>().ToArray();
      foreach (var clipping_plane in clipping_planes)
        if (clipping_plane.ClippingPlaneGeometry.ViewportIds().Contains(_view.ActiveViewport.Id))
          var plane = clipping_plane.ClippingPlaneGeometry.Plane;
          plane.Flip();
          _hld_params.AddClippingPlane(plane);
      //perform HLD calculation
      var _hld = HiddenLineDrawing.Compute(_hld_params, true);
      if (_hld != null)
        //transform and add to doc
        var flatten = Transform.PlanarProjection(Plane.WorldXY);
        BoundingBox page_box = _hld.BoundingBox(true);
        var delta2D = new Vector2d(0, 0);
        delta2D = delta2D - new Vector2d(page_box.Min.X, page_box.Min.Y);
        var delta3D = Transform.Translation(new Vector3d(delta2D.X, delta2D.Y, 0.0));
        flatten = delta3D * flatten;
        //add curves to doc
        var h_attribs = new ObjectAttributes();
        h_attribs.Name = "H";
        h_attribs.ColorSource = ObjectColorSource.ColorFromObject;
        h_attribs.ObjectColor = System.Drawing.Color.Cyan;
        var v_attribs = new ObjectAttributes();
        v_attribs.Name = "V";
        var cv_attribs = new ObjectAttributes();
        cv_attribs.Name = "CutV";
        cv_attribs.ColorSource = ObjectColorSource.ColorFromObject;
        cv_attribs.ObjectColor = System.Drawing.Color.Red;
        var ch_attribs = new ObjectAttributes();
        ch_attribs.Name = "CutH";
        ch_attribs.ColorSource = ObjectColorSource.ColorFromObject;
        ch_attribs.ObjectColor = System.Drawing.Color.Pink;
        foreach (HiddenLineDrawingSegment hld_curve in _hld.Segments)
          if (hld_curve == null || hld_curve.ParentCurve == null || hld_curve.ParentCurve.SilhouetteType == SilhouetteType.None)
            continue;
          var crv = hld_curve.CurveGeometry.DuplicateCurve();
          if (crv != null)
            crv.Transform(flatten);
            if (hld_curve.SegmentVisibility == HiddenLineDrawingSegment.Visibility.Visible)
              if (hld_curve.ParentCurve.SilhouetteType == SilhouetteType.SectionCut)
                doc.Objects.AddCurve(crv, cv_attribs);
              else
                doc.Objects.AddCurve(crv, v_attribs);
            else if (hld_curve.SegmentVisibility == HiddenLineDrawingSegment.Visibility.Hidden)
                doc.Objects.AddCurve(crv, ch_attribs);
              else
                doc.Objects.AddCurve(crv, h_attribs);
        //add points to doc
        foreach (HiddenLineDrawingPoint hld_pt in _hld.Points)
          if (hld_pt == null)
            continue;
          var pt = hld_pt.Location;
          if (pt != null)
            pt.Transform(flatten);
            if (hld_pt.PointVisibility == HiddenLineDrawingPoint.Visibility.Visible)
              doc.Objects.AddPoint(pt, v_attribs);
            else if (hld_pt.PointVisibility == HiddenLineDrawingPoint.Visibility.Hidden)
              doc.Objects.AddPoint(pt, h_attribs);
