Hi friends
I am a beginner and I would like to help how to make the evaluate curve receive more than one curve?
As shown in the picture
keep the SHIFT button pressed while you drag the second/third/fourth/… wire to the same input
by the way, I strongly advice against doing that, because you won’t see anymore in which order they were connected, and I advice to use the Merge component instead
will reply you also in your other thread, it looks like you might benefit a lot by having a look at this:
Thank you very much you helped me have a good day my friend I will listen to your advice
