I produced the attached trigonometric surface using trigonometric curves, and then two ‘4Point Surface tools’ (only 3 points were input into each - hence triangles) to produce the panels. I was wondering if ifs possible to produce a similar closed surface where the panels are hexagonal? I can’t figure out the maths.
Is there a way to produce a hexagonal-panelled closed surface in grasshopper using another method?
