Heteroptera can't be loaded
Hello everyone,
The Heteroptera plugin Version 8.0.4 and Version 8.1.5 both can’t loaded on my computer, I have install it several times from PackageManager, but it keep throw an error:
An error occured during GHA assembly loading:
Path: C:\Users\hx.li\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Heteroptera\8.1.5\Heteroptera.gha
Exception System.IO.FileNotFoundException:
Message: Could not load file or assembly ‘System.Runtime, Version=7.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’ or one of its dependencies.
Hi HazeLi -
Please run the Rhino SystemInfo command and copy-paste its output in a response here.
Thanks for your reply, here is the info:
Rhino 8 SR27 2026-1-19 (Rhino 8, 8.27.26019.16021, Git hash:master @ a7029e543145704b986eede4bc40b6bd8a0645d0)
License type: Commercial, build 2026-01-19
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9325.0
Computer platform: DESKTOP
*Standard graphics configuration.
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Ti (NVidia) Memory: 16GB, Driver date: 12-30-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.74
Accelerated graphics device with 4 adapter port(s)
  • Secondary monitor attached to adapter port #0
  • Windows Main Display attached to adapter port #1*
*Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 2GB, Driver date: 3-3-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device!*
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-30-2025
Driver Version: 32.0.15.9174
Z-Buffer depth: 24 bits
Total Video Memory: 16380 MB
E:\Code\CommandTracker-8\bin\Debug\net48\CommandTracker.rhp “CommandTracker” 8.0.0.0
C:\Users\hx.li\AppData\Roaming\Grasshopper\Libraries\Elefront\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\hx.li\AppData\Roaming\Grasshopper\Libraries\pOd\pOd_Rhino_2020.10.1.1.rhp “pOd_Rhino” 2020.10.1.1
C:\Users\hx.li\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.60519\net48\Karamba3D_LicensePlugin_Rhino8.rhp “Karamba3DLicense”
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.27.26019.16021
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.27.26019.16021
Hi HazeLi -
You should probably be running Rhino in the standard .NET Core.
Many other plugins(Including the plugins I developed myself) in my GH files use the .NET Framework. If I switch to .NET Core, it might cause many other plugins to stop working… I’ll try it, or maybe I should think of another solution… Thank you :sparkling_heart: .
