I have tried and failed for ~5 years to solve this problem with bricks.
One area can look fine but it falls apart somewhere else when all rows are not the same length.
here is my attempt:
Oh? Please do tell? Your “bricks” vary widely in length, which isn’t feasible with real bricks, though the gaps between them can vary to some extent. Even so, I see places in this image where vertical lines are aligned across rows, which is what you want to avoid.
Start with a spiral first and then lay the bricks?
This might be relevant?
P.S. Not quite that simple:
I am not sure if this is is ment to be sarcastic. It’s true that they are vary a lot, since this isn’t about actual bricklaying but about 3d printing pattern on a surface where spacing it is not so critical. This thread started out with the question about how to connect the layerlines without disrupting the pattern.
Maybe this is difficult, maybe one has to do the helix first. My only concern is by doing the helix first the same problem will shift to “how to distribute points on a helix so they are equidistant and form nice enough grid” which is equally difficult.
Absolutely not!
A brick laying thread/model based on contours, not a spiral, and using an “Impala” plugin (wait, that model seems to work without Impala?). Interesting but as I noted above, some vertical lines on adjacent layers are too close together.
I’m looking in this direction: (though not sure I really want to pursue this)
one problem occurs when the shape varies and the vertical lines run to close together:
my definition keeps some distance at the cost of a few vertical overlapping lines:
I realize that.
Does it depend on Impala or not? Seems to work without it, though looks quite complex inside that cluster.
I’ve just checked, impala is only used in the seam adjust cluster
where you can specify a location of the seam. Switching to “ownGeo” will require impala
Intresting!
May I ask how you will use your “tool path” to achieve the gcode?
I give it a go: kangaroo zombie solver to uniformize the “grid”.
Used the “Fattener” component at final step to achieve a simple mesh pipe…
nicely done! If have to take a closer look at your definition. At first glance it does the helix beautifully, but always keeps the same number of points in each layer.
Thank you.
it’s not so difficult: To make the printer move to a point {20,10,4} just tell it “G1 X20 Y10 Z4”
here is a screenshot of the part of the definition which generate the gcode:
For extruding plastic you have to figure out how much filament per mm you need but that’s it.
You didn’t internalize your surface so I used the Brep from @Konrad and Offset Surface isn’t happy with it, of course (it’s a polysurface).
… damn me…
To make it a single polyline, skip the partition component at the end.
Anyway, i’m trying a different code…
Probably overkill, and still needs tweaking.
Added a custom code to have a mesh piping, to avoid fattener plugin…
And I did internalize this time.
As probably many others already said, with non-constant circumference it’s impossible to avoid any alignment. Somewhere it has to have some imperfection.
Used zombie kangaroo to smooth isocurves and build a elix (maybe this step could have solved better)
Used zombie kangaroo on a Z scaled helix to make sphere collision to spread and de-align teeths.
Build teeth out of polyline and lastly piped to a mesh.
This method is surely wrong for big builds.
Probably an iterative method should be used, like: building the helix tooth by tooth and “foreseeing” the alignment with teeth on old layer, solving the problem as it reach and going on.
Kangaroo on big amount of layers and teeth will most surely fails and/or block rhino.
Whoa, thank you! Very impressive and a lot of effort
Yes, I think the trick is to hide the imperfection over a large area or to make everything a bit random so the mind just assumes perfection ;-). Similarly architects will draw jiggly lines to make them appear more straight then they are.
Thanks to your definition you posted earlier, I got an idea how to add a helix to my dot distributor ( the one posted here: "perfect" grid in 3 dimensions - #9 by Konrad). and the results are looking promising but to early to call it:
I believe this is correct, as a human brick layer would do, achieving “perfection” instead of hiding flaws.
Something like this…
vase_zigzag_V3.gh (52.6 KB)
It “looks” for lower layer and divide the remaining space into even spaces, always keeping the pitch larger than the give value.
It’s tweakable. imperfections are still there, nothing can be done to remove them… we know already.
My “for the lulz” ends here
By Jove, that looks very good sir! Well done. Please don’t stop as there are some anomalies near the top and who better than you to bring this to perfection? You’re so very, very close. BRAVO!!!
