Help with PythonScript
I have formatted my HardDisk an reinstalled rhino v5.
When i run a simple script like the attached image i get the error like the attached image
Vittorio
@vittorio,
you may check first if the modules are on the harddisk at the paths shown in your image. Then check if the module searchpaths are set in the python editor under:
Tools / Options / Files / Module Search Paths
i got these listed:
i remember that i have only set the last one. So you might try to add the above listed paths pointing to C:\ drive which are missing. The first path hosts the string.py module. Does that help ?
c.
Hi Clement
My Module Search Path looks ok
Vittorio
Hi Clement
I solved the problem with C:\Program Files\Rhinoceros 5 (64_bit)\Plug-ins\IronPython\Lib
Thanks for your help
Vittorio
