I have extended my previous curves to loop them as you can see in the image. However im not able to loft the curves to get desired result. I have attached my rhino and grasshopper file . Id be elated if i could find solution to my problem
Another thing I don’t understand… the Grasshopper definition contains curves in 5 branches but it seems they need to be grouped first. This is branch 1
I have uploaded a much cleaner file with all internalized grouped curves. i provided rhino file earlier so you could understand the profile ive been trying to create . Id be elated if you could take a loot at the latest file i have attached now
