Hi forum,
I’m trying to create a simple mould but I’m currently stuck. I’ve tried using Boolean Difference , but I can’t get it to work.
Here’s what it looks like before and after. There must be something I’m missing.
Any ideas? I’ve attached the file below.
File.3dm (479.9 KB)
theoutside
(Kyle Houchens)
November 10, 2025, 10:39pm
2
the seam of your part is exactly coincident with the face of your cube.. This is a common failure point for booleans
extract the top surface and trim it manually.
Tom_P
November 10, 2025, 11:16pm
3
any reason your initial surface is so complex - isn t it just a revolve ?
i built a new revolve and boolean difference works fine.
File-3_tp.3dm (1.1 MB)
also notice - if this should get a rigid mold - you’ll have some undercut:
happy modelling - tom
Lagom
November 11, 2025, 8:32am
4
Even better, lay of those boolean tools (there’s a good reason why there’s “boo ” in boolean) that seem to cause problems again and again, and use Rhino’s tried and trusted NURBS surface modelling tools instead ; )
Ah okej that make sense! Thank you for the explanation kyle.
I made it using a sweep, but I’ll try to remake it as a revolve. Thanks for the input, Tom!
Hahah, verkligen ett passande namn. Ska testa det!
Tom_P
November 11, 2025, 8:59pm
8
Det finns ett ‘Volvo’ i ‘Revolve’ – det rullar på bättre än Boolean! *
(* hopefully chat gpt did a good help with my first contact to your crazy language")
