Help with attractor perforation
Hi! I want to make perforation with crv attractor. It looks almost right, but when I zoom in, I see this, several circles in one. I know that its problem with tree, but I don’t know how to fix it. Can anyone help me?
please post your gh file with internalized geometries
read this: Help Us Help You - #10
in particular this:
attractor perf 2025 01 15.gh (50.1 KB)
attractor perf 2025 01 15.gh (53.3 KB)
Here is a more pragmatic and less laggy solution
there are a few things going on :slight_smile:
you first have created a triangular grid of cells, then have exploded those triangles to get their vertexes, but keep in mind that you have MANY overlapping vertexes
when you explode a closed Polyline, first and last point of the Polyline overlap
and if your Polylines are an array with all edges in common, then all the pairs of points of each edge are shared with the neighbor Polyline
original number of points is 125 thousands:
but the real amount of unique points is 15876, the rest are just duplicates of those:
this thing alone already brings the Point in Curve calculation down to 9 seconds from the 1.2 MINUTES it was before :smiley:
but we can do more: by using Closest Point on the Boundary Surface created on your initial planar curve, the total calculation time goes down to 1.3 seconds :+1:
my suggestion is to not be tempted to use plugin components that do a lot of work for you (instead of you) like the Attractor component of Lunchbox, but to build it yourself, in such a way to become very familiar with the reason why things happen, and develop your own workflow, for instance:
attractor perf 2025 01 15_inno.gh (56.8 KB)
thanks!
