Hello all,
I write because I need help with a script that I’m making for Rhino. The script calculates de area of the elements of each layer and print them into an excel file. It is necesary to have openned an Excel file previously. It works without problems, but I want to improve it making the following actions:
-The script must open an Excel file automatically, and must ask where we want to save it (the excel file).
-The script prints the x,y,z coordinates ot the centroid of each surface in an only column, but it should printe each coordinate in a differente column (a column for the “x” coordinate, another for the “y” and another for the “z”).
The script is the following. Please, could you help me with the two improvements that I need to make? Thank you a lot
Option Explicit
'Script written by <insert name>
'Script copyrighted by <insert company name>
'Script version sábado, 26 de mayo de 2012 12:16:58
Call Main()
Sub Main()
Dim capas,numcapas,strlayer,arrobj,strobject,arrarea,strarea,arrcoord,strcoord,j,xlapp,xlsheet,xlbook,arrlobjects,centroidlayer,layercoord
capas = rhino.LayerNames
numcapas = rhino.LayerCount
j = 0
For Each strlayer In capas
Rhino.CurrentLayer strLayer
'FALTA INVESTIGAR-CONSEGUIR CENTROIDE DE VARIAS SURF A LA VEZ
'arrlobjects=rhino.ObjectsByLayer(strlayer,False)
'h=rhino.SelectObjects(arrlobjects)
'centroidlayer=rhino.SurfaceAreaCentroid(h)
' If Not isnull (centroidlayer) Then
' layercoord=rhino.Pt2Str(centroidlayer(0))
' End If
'RHINO.Print strLayer
If Not Rhino.IsLayerEmpty(strLayer) Then
arrobj = rhino.objectsbylayer(strlayer, False)
For Each strobject In arrobj
arrarea = rhino.SurfaceArea(strobject)
If Not IsNull(arrarea) Then
strarea = rhino.Pt2Str(arrarea)
Else
Rhino.DeleteObject(strObject)
End If
'rhino.print(strarea)
arrcoord = rhino.SurfaceAreaCentroid(strobject)
If Not isnull(arrcoord) Then
strcoord = rhino.Pt2Str(arrcoord(0))
End If
' rhino.print(strcoord)
' Open Excel object
On Error Resume Next
Set xlApp = GetObject(, "excel.application")
If err Then
Rhino.print "Excel not found. Operation aborted!"
Exit Sub
End If
On Error GoTo 0
xlApp.Visible = True
Set xlBook = xlApp.ActiveWorkbook
Set xlSheet = xlBook.ActiveSheet
'Place titles on sheet
xlApp.Cells(1, 1).Value = "CAPA"
xlApp.Cells(1, 2).Value = "Surface Area"
xlApp.Cells(1, 3).Value = "X centroide"
xlApp.Cells(1, 4).value = "Y centroide"
xlApp.Cells(1, 5).value = "Z centroide"
xlApp.Cells(1, 6).Value = "Centroide Global por Capa"
'Extract Properties of Surfaces
xlApp.Cells(j + 2, 1).Value = strlayer
xlApp.Cells(j + 2, 2).Value = arrarea
xlApp.Cells(j + 2, 3).value = strcoord
xlApp.Cells(j + 2, 4).value = strcoord
xlApp.Cells(j + 2, 5).Value = strcoord
j = j + 1
'xlApp.Quit ' If closing excel is required
Set xlApp = Nothing ' the application, then release the reference.
Next
End If
Next
rhino.Print("FINISH!!!")
End Sub
