Some of the models are having difficulties if I ''Check" them.
For example:
Mesh has 20 non-manifold edges
Mesh has 14 duplicate faces
Mesh has 12 pairs of faces that intersect each other
Mesh has 12 naked edges.
So my questions are: Can I do something in Rhino to solve those problems? And are these problems critical for 3D printing it? I’ve tried ‘‘MeshRepair’’ but it didn’t solve the problem.
Hi Jesse - self intersections are hard, actually, and naked edges you’ll need to fix by hand,(Use ShowEdges to see where they are - the tools to use will vary with the situation- feel free to post a model and I’ll take a look.
I’ve just used the commands ExtractDuplicateMeshFaces & ExtractNonManifoldMeshEdges, that resolves the duplicate meshes & non manifold edges problem but than I end up with more naked edges than before… In this particular model, the naked edges went from 0 up to 17 after the 2 commands. Also it becomes an ‘‘open mesh’’ and before the 2 commands it is a closed mesh…
If you can take a look at this model, I would be very grateful!
The model I uploaded is from before the commands you recommended.
Your mesh has problems in 2 areas that are pretty easy to repair manually.
If you look at the Non-Mainifold edges in your mesh, you will see that they are located where there is a small bridge between 2 strands of the goat’s beard.
Hi! Is their a clean way to do that with a python script for a list of meshs? I can do a proximity check with the created curve of all my meshes and then fill all the holes, but is their a cleaner way to do it?
