Hi there,
Really new to Rhino here, just started two weeks ago so please bear with me if this is a really simple question.
I’m trying to draw the base between these two solids
First, I extruded a curve all the way past the right side.
Then, I extruded the extrusion created from step 1 upwards by 0.5 cm.
Now, when I tried to trim the new extrusion using the right side as a cutting object, it deletes my entire new extrusion instead of only the outer side.
Could you please teach me what I am doing wrong?
These are the object properties of the right and left sides, as well as the base.
Thanks for your time! Much appreciated
PS: I have tried to do this in my girlfriend’s Rhinoceros on windows, and it is still unable to trim how I wished it to.
