Well, I sure hope it’s just one 1/4-20 and not 1500 2-56’s with elastic stop nuts. Is it top priority?
Thanks for the update.
Won’t work for me unless it’s metric… ![]()
No, it’s not.
I see you’ve fixed a lot of things in the latest release, so maybe there’s some resources available for this? Is there any hope of making this happen soon, or is it still on the “all talk, no action” list? It’s sad to be required to go to a separate computer to consult the help, and it sure is slow compared to having the automatic command help available almost instantly.
Even an estimate on when you can get to it would be helpful.
Hi Al,
Thanks for the reminder. There’s not a lot left to do here; I’ll try to get it in SR5 for you.
That’s great!
Also: I assume you mean on this particular feature? ![]()
A couple questions for those of you that want offline help:
- What web browser are you using?
- Are you interested primarily in:
a) Pressing F1 inside a command to see help
b) Using the Help panel while inside a command
c) Browsing the help from a generic starting point
It appears that, right now, all of these are possible if your default browser is Chrome. If your default browser is Edge or Internet Explorer, then (a) and (c) will work.
The details are that for (b) to work, a URL like this gets created:
file:///c:/somewhere/on/your/computer/help/en-us/index.htm#commands/circle.htm
But for IE and Edge, the “#commands/circle.htm” get removed, and the browser just shows the “Welcome to Rhino Help” page. If this is adequate, then I can get this in SR5.
My default browser is Firefox. Surely I’m not the only one!
- Firefox,
- Help on F1
- AND Help panel while inside a command
I always have Firefox full of open tabs (RhinoCommon / GrassHopper SDK). Terribly slow to search, and no stemming (requires knowing exactly what to search for when trying to search for what to learn to know…)
For decades Help/F1 used to work for windows applications, but Internet destroyed it all.
// Rolf
Chrome.
That’s why I asked! I don’t have FF on my machine, but I’ll install it and test with it.
I think option b) is the thing I’m most interested in. That’s where I have a help window open in Rhino and whenever I start a command, it’s help info shows up automaticallyin that window, right? Having a) would be borderline acceptable; c) barely better than a sharp stick in the eye - although better than doing over the net from a separate computer.
I currently have Explorer as my default web browser.
When will SR5 be available? I need Help and the machine I have to use for Rhino is not connected to the Internet.
https://drive.google.com/file/d/1pDYiYaMGsExp6SlJtPRa6fBbmKFitHsb/view?usp=sharing
This is the help files that you can use offline. It has no interaction with Rhino until RH-43313 is fixed.
Thanks. I’ll try that.
It turns out that the changes required for offline help are too significant for me to put into SR5; but know that the bug fixes are on the way. I hope to have this in the first SR6 release candidate.
RH-43313 is fixed in the latest Service Release Candidate
To get offline help, download and run the RHI from:
https://www.rhino3d.com/download/Rhino/6.0/Rhino6OfflineHelp
The Rhino help file does not work - when I click the rh60-help-en-us.rhi file, installation windows appears, I click “next” button in the window, the window disappears, and nothing is installed.
