dear experts,
I got an question, can you help me?
Since karamba3D is connected by a touch, would it be calculated if the actual cable in this place would exert a lateral pull on the column? Because it is different from the normal beam and column system, the beam is not overlapped on the column, and the column does not produce force.
If your cable is attached to the column and you apply a pulling force or a pretension to your cable force.
