Hi All
How do I delete a curve?
I always get an error
# coding: UTF-8
import scriptcontext as sc
import Rhino
def deleteCurve():
Return list of curve and edge
filter=Rhino.DocObjects.ObjectType.Curve
rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select curve", False, filter)
if rc != Rhino.Commands.Result.Success: return rc
#pt=objref.SelectionPoint() #punto di clik
curva=objref.Curve()#id curva
table=Rhino.DocObjects.Tables.ObjectTable.Document
print table
sc.doc.Objects.Delete(curva)
deleteCurve()
Message: Delete() takes exactly 2 arguments (1 given)
Traceback:
line 17, in deleteCurve, "C:\Users\Angela\AppData\Local\Temp\TempScript.py"
line 21, in <module>, "C:\Users\Angela\AppData\Local\Temp\TempScript.py"
Ciao Vittorio
menno
(Menno Deij - van Rijswijk)
April 4, 2014, 6:22pm
2
sc.doc.Objects.Delete(curvea, True)
Should do the trick. The second argument is for quiet - if not quiet, Rhino will show a pop-up if the object can’t be deleted. If quiet, it will ignore the error and keep going.
Apart from that, you are supplying an object to the Delete function, while it requires a guid:
# coding: UTF-8
import Rhino
def deleteCurve():
curve_id = objref.Object().Id
sc.doc.Objects.Delete(curve_id, True)
rs.Redraw()
deleteCurve()
stevebaer
(Steve Baer)
April 4, 2014, 7:53pm
4
There are overloads to the Delete function that take Guids, RhinoObjects, or ObjRefs so both of your solutions should work just fine.
Thanks djordje
Your example it’s Ok
Ciao Vittorio
