Headless Rhino
For batch processing, I was wondering if Rhino can be started in headless mode, i.e. as a command-line program, not showing any GUI.
Hi Menno- I think this is possible - check with the developer group…
Thanks, I’ve changed the category accordingly…
Hi Menno,
you can switch off visibility:
rhino.Visible = 0;
Here you’ll find some automation samples:
https://github.com/dalefugier/SampleCsAutomation
And watch out for this bug:
http://discourse.mcneel.com/t/tell-running-rhino-application-to-execute-script/24058/18
  • Jess
Hi Menno,
What you are asking to do is possible but challenging, as the only to access Rhino externally is through ActiveX automation (e.g. COM). Writing COM in C++ isn’t much fun, so you might consider .NET
Here is an example you might find useful. It demonstrates how to create a command line application that launches Rhino and calls into a plug-in. Because COM is the only way to communicate with Rhino, externally, the Rhino plug-in must provide a COM object that can be accessed.
https://github.com/mcneel/Rhino5Samples_CPP/tree/master/SampleAutomation
There are also .NET equivalent samples that @Jess has posted above.
A post was split to a new topic: Run Grasshopper script with custom UI
