@fsalla - is this something you can look into?
Hi @Clayton_Muhleman, @dale I cannot reproduce the crash in my PC, with the same file.
Iâm currently using VisualARQ 3 Beta 7 and Rhino 8 SR7. And I just have VisualARQ and Lands Design as third-party plug-ins enabled.
@Clayton_Muhleman are you using these versions as well?
When I open the file, I get these warning messages from the âOpeningToolsâ:
I ignore if that plug-in has anything to do with this, but try to disable it to test if the problem persists.
I cannot find in your file the drawing of your first video in this thread. If you can record a new video with the crash happening on the file you sent me, it will help!
Even with rhino 8.8 the problem still persists, whenever i try to select a hatch and zoom in it just crashes 100/100 times, with importing .pat files from autocad, the hatch command after selecting curves just crashes. Please fix this guys. Rhino 8 is really powerful but this problems have forced me to go back to rh7 for 2d draftings
Hi Sadikur Limon,
Please run SystemInfo in your Rhino command line and post the results. Thanks
Rhino 8 SR8 2024-6-11 (Rhino 8, 8.8.24163.12481, Git hash:master @ ded4d86ca901dbeaf13ee84f79b3e91b22da4880)
License type: Commercial, build 2024-06-11
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9241.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp âDisplacementâ
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp âSectionToolsâ
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp âPanelingToolsâ
If you can send us a file with a hatch in it that we can repeat the crash with, we should be able to fix this issue pretty quick
hatch crashes.3dm (364.5 KB)
I imported autocad .pat file and then when i want to use hatch command, it crashes. If it doesnt crashes then when i select the hatch and zoom in to or change the scale from properties panel, it crashes. Please look into it. Thanks
Any particular reason to be running in 4.8?
to run some plugins that i have disabled recently
Iâm not able to crash Rhino here with that file.
What happens when you set this back to the default .NET Core?
Also, Iâm not seeing any crash reports from you. Does the crash reporter pop up when Rhino crashes on your system?
hi,
i went back to the.net core, and magically, rhino doesnât crash anymore
Yes, it pops up, but I did not send it sorry.
For now, my rhino is not crashing. Thanks a lot. You guys saved me!
Same problem. R8 crashes consistently when trying to apply a new hatch:
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, build 2024-06-18
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32GB)
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
- Windows Main Display is laptopâs integrated screen or built-in port
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Total Video Memory: 6141 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp âCommandsâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp âMeshCommandsâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp âGrasshopperâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp âCalcâ
Any particular reason you are using 4.8?
This is an interesting configuration. With no plugins to remove this seems like a good place to troubleshooting by removing monitors and switching the display port.
I wasnât aware until you pointed it out. What should I use?
I tried the hatch with no monitors (the dock was unplugged.)
Same result.
unless you have reasons to run .NET 4.8, use the default:
Command: SetDotNetRuntime
Currently running .NET in NETCore
Select .NET Runtime ( Runtime=Default )
