Rhino crashing on Windows 11
Rhino V7 & V8 are crashing when I use splash screen to open a file at startup.
This started occurring after a windows 11 update a couple of weeks back.
I’ve sent in the rhino crash reports.
I’ve completed a clean reinstall of nvidia drivers.
What’s the next step to sort out?
Below is the system info.
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
Primary OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 2-21-2024 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-2-2024
Driver Version: 31.0.15.5212
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Bongo 3.0 (64-bit)\Rhino6\Bongo.30.rhp “Bongo 3.0”
C:\Program Files\Bongo 3.0 (64-bit)\BongoEtoUI.rhp “BongoEtoUI” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
That is very unusual, especially for the specs.
A quick troubleshooting method is to copy your Rhino Desktop Shortcut and add a no splash screen flag on startup.
Can you roll back the video driver?
“C:\Program Files\Rhino 7\System\Rhino.exe” /NoSplash
Hi Japhy,
Thanks for the reply.
Opening via the New & Recent tabs on the splash screen will cause a crash.
Opening via the Open tab and also clicking on the License tab on the splash screen doesn’t cause a crash.
The previous video driver was causing a crash after the Windows update which is why I updated the driver.
I can still use Rhino but would obviously like to sort out the crashing issue.
Hi Cian -
I suppose it wouldn’t hurt with a Repair of the Rhino installation from the Windows Control Panel.
Hi Wim,
Thanks for the reply, as a precaution did a repair before emailing in.
Cian
Hi Cian -
Just to make sure, …
Disable the Bongo plug-in in the Plug-in Manager and restart Rhino. Does that change anything?
Hi Wim,
Yes that is where the crash is coming from.
Disabled Bongo and no crash using the Splash Screen.
Checked on V7 & V8.
Cian
