i like the filtering, looks like a breeze to clean that out, compared to all these awkward filters these days.
i assume the kink in the suction intake inside is to get circulation starting and room to develop through the filter?
I have this silvercrest wet and dry handheld vacuum cleaner I use to clean my car so it’s based on that one with a different design
The real filter is actually really easy to clean it has this fabric mesh so the dirt and dust does not stick on it and flexible rubberlike that can be washed
It’s supposed to have different nozzles that activates a lid I think for liquids
So it’s more visual
Impressive modeling skills, I have the same Silvercrest vacuum. The filter is pretty easy to clean out, but it’s encased in some sort of plastic cage with large holes, so sometimes debris get stuck inside. I think the kink in the suction line is so that when you are vacuuming up water, you are holding it at an angle, and when it fills, it’s still over the surface of the water, so it can still fill, and when you stop vacuuming the water doesn’t just flow out (It has a little rubber flap to stop that from happening, but it’s not very effective).
Thanks, it’s probably how it works I never used it for liquids so never tried it, the max logo is probably for it to
Didn’t want to open mine because it had dirt ![]()
